I messed up. Need help.
White Collar
Nick Petersen
My tech got sloppy while spraying a solvent based grout sealer on the grout lines.
It's my fault because he hasn't been working very long and is an amazing worker. I should have watched him better..
Anyways, is there anyway to get grout sealer off these cabinets without hurting the wood?
I'm so stressed. Any ideas would be great!
Steve Lawrence
I'd try what Shawn suggests. Use a clean terrycloth rag. The sealer should dissolve the sealer on the cabinet and allow you to wipe it off. Good luck!
Wandslinger
Tom Meyer
Just wipe it off with a damp cloth. If that doesnt work, apply some more sealer on a rag and wipe. Also, use the rapid seal system next time.
mirf
David Mirfin
I would try more sealer first. anything else try in a more hidden location.
Reactions: Steve Lawrence
Zee
How "old" is the sealer? As in how much time did it have, to cure on the wood?
White Collar
Nick Petersen
Thank you everyone for the great responses so far.
We sealed it today at 11:30.
I haven't been able to get back yet. Hopefully tomorrow.
There is some very good ideas on here.
I also read somewhere that goof off may work. Anyone know much about goof off on wood?
What is the rapid seal system?
Steve Lawrence
Nice to see someone come pick the best brains in the industry to help with a challenge.
Okay, maybe an issue, but never a problem.
John Olson
John Olson
Can I use your picture for my "what to never ever do and why you always use tape and plastic 4' up and don't take it down until your ALL DONE" file?
It's about time you had some self awareness Marty as to what you are : )
