Ramp for people in wheelchairs to ride over hoses on sidewalks?
Bee Busy
Folsom CA
Bee Busy
Does this exist? I thought I saw it on another CC'r page a long time ago. It's a ramp designed for people or wheelchairs to to walk over the hoses with the hoses running underneath, designed in major public walk areas, I need something like this for an upcoming job in the downtown area.
San Francisco, CA
It exists.
You can get it from most suppliers. If I remember correctly Scott Warrington's outfit makes it. Bridgepoint.
Bought it a long time ago. It was about $250.00
dgardner
Phoenix, AZ
Dan Gardner
This one Ofer?
http://interlinksupply.com/index.php?item_num=AR008
It's about 300 beans now...
Reactions: J Scott W
San Francisco, CA
Yep.
That's the one. Not perfect but it works. As long as you don't use 2.5" hoses.
It will fit a 2" vacuum hose, a solution hose and the water hose. A bit tight but it will fit.
You'd still technically be in violation of the Americans With Disability act, but since you're not in S.F it will probably do just fine. And disabled people or moms pushing a baby cart really appreciate it.
Ray Burnfield
Redwood City, CA
Ray Burnfield
Be careful with that ramp. Cities have different codes for access.
It's not legal to put that ramp on a sidewalk in San Francisco.
San Francisco, CA
It is not legal but we do it all the time, as the required solution is 100% not practical:
15 feet long ramp (5 angled, 5 flat and 5 angled) + Needs to have a railing on both sides + the traffic on the side walk needs to be funneled (with railings) towards the ramp on both sides, so that blind people can 'safely' get through.
A joke- Totally impractical.
Reactions: dgardner
I believe you'd still have to jump through hoops going overhead too... Scaffolding, ect..... Fk um I say...... Add the price of the ticket to the bill..... If you get sited, you can pay it.... If not, refund the money..... :lol:
Bee Busy
Folsom CA
Bee Busy
I'm going to build something with wood going overhead like Lee, suggests, this is unbelievable, so I better cover my ass, thanks
Ann Arbor
Steve Lawrence
We use this one. You can run 3-2.5" hoses under it. City officials liked it when they walked by one day but I really don't know if it's legal. I don't like using it because nothing is totally safe but it works for us when we need it. It was about $800 about 7 years ago. Made of stainless. Not sure who sells them now.
Brian H
Detroit Michigan area
Brian H
We use warning signs when our hoses cross a sidewalk.
I would be afraid of the liability of having a ramp, unless it was cleared by some regulatory body. All it takes is someone to hurt themselves using it and then you are open to a lawsuit.
I thought hand rails and the ability to handle any possible mobility device were mandatory in SF/CA
In other words the GG bridge...
dgardner
Phoenix, AZ
Dan Gardner
Are you saying that if someone, in spite of your warning signs, trips over your hoses there won't be a lawsuit?
Brian H
Brian H
As Richard says, there is always the potential for a lawsuit. I just think that the potential is higher when using a ramp unless it has some sort of certification, etc.
Reactions: dgardner
Bee Busy
Folsom CA
Bee Busy
Well...sheet! I wanted to do something like what Lee said but the sidewalk is slopped and will cause my idea to tip over. Those ramps aren't ADA compliant here in Commiefornia. I'm going to have my helper stand out there and verbally warn everyone and lift up the hoses for anyone that can't get over the hoses.
Use metal pipe with 90° bends and 25-45 pd weight bench weights to hold it down... Or figure out a way to attach it to van using a tow hitch if you got one making like a hangman stand....
Reactions: Bee Busy
San Francisco, CA.
Going overhead with the hose is BEST if you are going to be at a jobsite a long time. I made a Hose "Door Way" to hold the hose above ground made with 2 inch PVC pipe but no longer use it.
I use that same ramp in SF.--- Since we are seldom at one job site more then 2 hours---I hear we only have to make a reasonable attempt to solve the wheelchair problem. We are required to block the sidewalk and channel the pedestrians on to the ramp-- but this pisses more people off.
The Ramp will break apart at the hinge because it is only held together with 1/4 inch screws!!!
I guess the designer forgot it would be used by Carpet Cleaners.
I fixed it by using 1 inch flange steel rivets.
San Francisco, CA.
San Francisco, CA.
How long is that ramp? I would think the incline/decline is too steep and could cause tipping hazards for powered wheelchairs.
The yellow one can fit a 2.5 inch hose- but its not easy.
