How do you clear clogged jets on your Hoss?
Johnny
La-Z-Boy
Johnny
And keep them clear? I've been plucking bristles from steel brushes with my Leatherman.
Johnny
La-Z-Boy
Johnny
Find the source of the crud and install an inline filter
Ours never plugs.
It should have come with one?
I keep the stock filter clean. Suspected the encap component of End Zone, but my other rinse tools don't clog with EZ.
Boca Raton
100 mesh filter. I would pull the disc and turn up the pressure and try to blow it out first. I hope mine never clogs. I have had to replace the filter when they get clogged with encap rinse. Never a jet yet.
Gene
Reactions: Johnny
Mike Draper
Always make sure your water is nice and soft and you'll never have a clog again. You should cleaning with soft water and a rinse.
Louis
Modesto, CA
Louis
A shark brush or stainless brush. A tiny bit of crud that dries on them will plug them. I have 2 inline filters on mine and they still plugged . Quick brush and your back in Business. I have been running mine with no disk in it and it cleans great. The needle valve is going on next.
Total_Rookie
Beaumont, CA
Joseph Torrez
Consistently or one or two times atnyour house?
You live down in the So Cal desert, right?
Humidity does factor an offset at times. Although most of the times its dry climate here.
All jobs have follow up calls within 48 hours. We ask how long it took to dry.
We have our carpets cleaned once a year. Just use the wand, dry in 2 hrs
La La Land
from my own experience i found that most of the time it's small shards of rubber from QD O-rings...
take the jet off put on yor extra jet that you carry in yor pocket and then blow the clogged one out backwards when ya get home
