- Mar 24, 2009
- 3,547
- Name
- gene miller
I went through two packs today. I cleaned some wool area rugs, a 28' white sectional, white carpets and a urine soaked pottery barn wool rug. It seems to work fine and kill odors fairly well. It's a little hard to get used to. You are supposed to dump the entire bag in a 5 gal. Bucket and then use it. Instead I dumped the two bags in an old container and scooped it out. I mixed one scoop per gal. Each time I rolled and mixed the container. I understand the reason behind dumping the whole bag but it's not convienant. If I'm going to buy it I might as well test it the way I'll end up using it. By the last job what was left was pretty caked up. It clearly absorbs moisture from the air easily. One of the small bags turned into a Mylar ballon just from being in my garage. It has no odor and the products are fairly innocuous. I like it so far but not sure I could get used to the bags.
Gene
Gene
Uhm, yeah, it DOES lose carbonation after awhile. BUT it's still a very effective cleaner even when the bubbles are gone. Tonic water? Interesting thought ... we've often said we're club soda with a club!
