- Oct 6, 2006
- 117,065
where does the water softner go?
I have been asking for remote for years. It will be so nice to clean upholstery and then carpets without going out side. Is the wire cage to hold the filter bag so it doesn't suck in the bottom hole?
I like to pull the vac hose off the port when other guys are cleaning and then take off.![]()
We have been cleaning carpet and upholstery at the same time for decades without having to go outside for any adjustments.I have been asking for remote for years. It will be so nice to clean upholstery and then carpets without going out side. Is the wire cage to hold the filter bag so it doesn't suck in the bottom hole?
that thing would be broke or lost in a week![]()
Yep!We had someone once shut the truck off and take the keys out at a commercial job. Whoever it was took the keys with them. We had to run a spare set of keys out to the crew.I like to pull the vac hose off the port when other guys are cleaning and then take off.![]()
Yikes!
I had to run a spare set out Tuesday they were loading equipment into the truck and locked it up each time because they were above ground level. I thought the tech was an idiot but the key did have a crack in the ring portion and fell off insdie the van.![]()
