Harbor freight engine??!!
joeynbgky
Joey
This is a honda clone. Its on sale for $699.00 and i can get it for $525 with a coupon.
My Honda has 4100 hours on it and may go soon.
But a Honda is 1500 bucks plus a 200 muffler.
This clone comes with the muffler. I dont need an engine yet.... im leary of harbor freight stuff. But do you think its worth a try? Just curious its a hell of a deal.
Well it's your gamble looks like it would work but I doubt you get Honda results and life cycle out of it
Will not have the durability of the new Honda 22.5HP engine.
Too new to know actual hours, but I would guess about 1/3 the number of hours.
Engines are not the item to skimp on.
Also, the 20% off coupon doesn't apply to Predator engines.
joeynbgky
Joey
I agree but if it lasted 2,000 hours. Looks like it could be a lifan engine. Not sure...my honda is a 24hp which im sure is really 22 now.
Reactions: ronbeatty
D
dgardner
It would be interesting to see how long one lasts with good maintenance. At that price you can afford to buy two and keep one for a spare...
Reactions: Dolly Llama
If a direct fit, I'd try it.
like Dan said...buy two
only real complaint I've read about them is the idle is too high (1800 rpm) for centrifugal clutch go-carts
Mrice
Mat
You can also buy a 3 year extended warranty from them I believe, and I don't think the coupon applies to engines, generators and a couple other things.
joeynbgky
Joey
I dont have a problem spending more money on a honda... but im just curious about this. If it breaks down during busy season. I can go get a honda. I have an open tm. Tcs. So it looks like i could probably remove old engine and install the new one in under 10 mins.
Noble Carpet Cleaners
I have an almond farmer customer that put the Harbor Freight 22 on a portable augar. Runs the crap out of it two seasons in a row. Runs full throttle all day for weeks.
With the lifan motors, it really comes down to if you get a good one and do the maintenance before it calls for it.
Many manufacturing companies ( carpet cleaning) are using the motors with pretty good success.
You will need to adjust valaves and such a bit more often on the cheaper engines.
Reactions: dgardner
M
Mike Draper
run soft water and dont freeze it, you should never have a problem with aLG
Goomer
Frank Mendo
Looks like it could be a lifan engine. .
I've heard good things about Lifans in general.
Don't assume anything with such a vital purchase.
Foolish to pull the trigger without being sure of exactly what your buying.
Lifan or not a Lifan…. That is the question.
Reactions: Jimmy L
