- Nov 8, 2006
- 5,111
- Name
- Shorty Glanville
Mikey, one thing I found that was a pita with the docking station was that it had to be emptied via vac; hose, or tipped over.
I installed a three way tee piece where the water line goes into the pump underneath.
To this I connected a hose which I tied off along the pressure line under the machine.
Fitted a tap at the far end, then when finished, would simply turn the tap to drain the tank while I finished loading the rest of the gear, etc;
I still believe that it is far too awkward for taking up/down stairs.
Too much weight out over the front end.
