Mike Draper
- Jan 13, 2008
- 4,402
Here is an upgrade I just did. Lance the water expert helped me out. Carbon, chlorine and fine sediment. Then to the water softener.
???Mike how much is your service charge to Gardnerville?
It doesn't look like there is enough room to unscrew the filter housings. How do you service the filters?
If you moved the assembly up a few inches would you be able to remove each bowl to service the filter?
