Lance golden hooked me up.
dgardner
Phoenix, AZ
Dan Gardner
It doesn't look like there is enough room to unscrew the filter housings. How do you service the filters?
If you moved the assembly up a few inches would you be able to remove each bowl to service the filter?
Mike Draper
Correct, I have to loosen the 2 bolts on the brackets and slide up the whole system in order to get the filter housings off. With all the water in the housing, its to heavy and not strong enough to drive around without bending the main bracket.
