This was at Pembertons this past friday. Rick is a hoot, and Jim is always a pleasure to be around. Lee Pemberton was also there, raffelling off the give aways.
what wand you running with your cleanco?Yep, I completely understand. I took my jet extenders off for that exact reason.
I use the ProChem Ti, but my son always brings the Greenhorn when he's with me. Both are good wands. He just likes the Greenhorn (CMP) because it's shorter. I like the Ti, because I'm tall and it fits my height better, but the Ti is too light. I like the Greenhorn because it is heavier and rides the carpet better.
I can use either wand, but I keep the Ti on my van because the boy likes the Greenbean wand.
Don't be a caveman Pigsnot. Pull out your Zipper!I use the ProChem Ti, but my son always brings the Greenhorn when he's with me. Both are good wands. He just likes the Greenhorn (CMP) because it's shorter. I like the Ti, because I'm tall and it fits my height better, but the Ti is too light. I like the Greenhorn because it is heavier and rides the carpet better.
Why do I constantly find myself having to point out the obvious to you, Taco?
Separate pressure regulators in order for it to be a true dual wand? I don't think so.A true dual wand machine would have independent pressure regulators. The streaking wand should be turned down a bit.
LOL
its a ritual...well honestly everyone gets it.![]()
You're acting like it
That's one of his most endearing qualities.says the man who bickers with with the other man everyday like little kids.
That would limit both flow and pressure and is adjustable way down. Have you run dual wands a lot and found the need for separate pressure regulators?That would limit flow, with varying results.
Pressure would be the same.
