Excellent Vario OP Machine question..
how in the heck do you pick this thing up?
nice big wheels but no grab point out front..
ifJeDSHoe7NOZm3C3Vsp8GI_ERI5OVSYzP9Mixk0O0KGO6Px-YsFtZlDJj84HPEzhlkYEzEyOARZUDPeMWo=w560-h995-no.jpg
@Mike Draper are you using a ramp or a helper to get it in the back of your box truck?
jwfoulk12
Justin Foulk
I use a ramp... Not trying to tweak my back by trying to lift it in and out of the van.
Like my buffer I would tilt it back grab it by the tank opening and the front of the bottom. Helpers just get in the way.
Cant do that with the driver set up on this unit...nothing to grab that won't destroy your fingers out front.
Mike Draper
all I know is I love that Vario 2. easier to use than the 175, scrubs better and uses very little chemical. It is so easy to push to the front door and effortlessly manuevers around the home. 175 is going up for sale.
That's what I wanted to hear..
What pad are you working in pre-pay with?
Ever run your HWE prespray through the tank?
jwfoulk12
Justin Foulk
My ramp is just a piece of plywood about 3.5 ft long and just wide enough to fit the wheels. I only have it on the truck when I have the Vario on so it just gets shoved in beside it. I don't have room in my truck to leave it on all the time.
Mike Draper
I've been running ultra pack through it as a pre-spray. Using a beige pad with horse hair or something. its a popular pad, but cant think of the company name. i'l do a thread on some results...
Mike Draper
none, I've been wathcing carefully. on 1 job I was a little concerned so I used white pad. No negative affects.
handdi
Randy
ashley posted a pic of some ramps that looked pretty dang good
encapman
Rick Gelinas
Usually you can hoist it by grabbing the front of the machine with your right hand wrapping your fingers under the bottom of the pad driver (easier to do if the bonnet is still attached) and holding the back of the handle where the handle locking lever is located with your left hand. It's a little awkward to lift the machine like that, but it's doable. But my preferred option is to use a ramp (I'm old and lazy).
This aluminum ramp is AWESOME. I use it personally and love it. It is lightweight and has a monstrous tread grip. Makes it very easy to pull the Vario or other equipment into most vans. http://www.excellent-supply.com/Lin...pet-Cleaning-Machines-and-Equipment_p_14.html For taller vans, this ramp is also excellent. http://www.excellent-supply.com/Link-Ramp-81x24-bi-fold-aluminum-ramp-LWS40-24-81_p_325.html
Reactions: dgardner
