encapman
- Oct 7, 2006
- 2,405
- Name
- Rick Gelinas
Here is a quick question for you guys who use super high heat. I was asked to help someone with this. The carpet has recently been cleaned with a kerosene heated truck mount. There are clearly indentations in the cut pile carpet from the jets. It's as if the carpet has been distorted where the solution had been sprayed. An attempt was later made with a cylindrical brush machine to try to correct it. That improved the condition a little, but it still has the indentations. The indentations look like the fiber has lost its resiliency. I'm pretty sure this was caused by extreme heat! Do any of you guys have any suggestions to fix this, aside from replacement?
Here's a picture.
Here's a picture.
