Heaters for your vans
Grand Rapids, MN
If you do not have a shop...(but if you live in as cold a climate as me you really should!)
I was walking around the local L&M Fleet Farm tonight and thought would take a pic of some heater options...
If you are doing this kind of heater, you really do need slight air movement to circulate the heat...
You will also want at least 2 heaters....and EACH ONE ON A SEPERATE CIRCUIT WITH NOTHING ELSE ON THAT CIRCUIT!
So if you run 2 heaters and a small fan...you will need 3 circuits....
Each one of these heaters can put enough stress on a circuit to blow the circuit....
Some of these also WILL NOT RESTART THEMSELVES IF THE CIRCUIT BLOWS.
Some of these units have a fan...some do not...
Also, some are still a fire hazard if you get something flammable around them (or fuel fumes)
So just some pics and ideas for those of you saving up for a heated shop :)
I DID NOT TAKE ANY PICS OF OIL FILLED...THEY ARE OK...But I don't feel they really put out enough heat fast enough....
Able 1
Wi
Keith
Yes that's the one.. I also have a industrial in line thermostat that I set to 50 degrees and put it next to the heat exchangers.
Reactions: Mark Saiger
Able 1
Wi
Keith
My other van is at home in a garage with a furnace, much more comfortable with that set up..
I do also cover my truckmount in my off site van with a bunch of blankets, and blow the heater under them..
dgardner
Phoenix, AZ
Dan Gardner
Most of the heaters with digital controls won't come back on after a power outage (even a brief one) and should be avoided. Heaters with basic manual controls, such as the so-called "milkhouse" heaters will.
http://www.walmart.com/ip/17808701
In any case, test any heater you buy by pulling the plug, and make sure it comes back on when you plug it in!
Able 1
Wi
Keith
The Stanley will come back on.. I also have the heater you posted Dan. I like the size and shape of the Stanley.. Or maybe it was the color.. :lol:
Reactions: dgardner
Boca Raton
My father-n-law always blows out the lines at the lake house in northern Maine. Ashamed they don't put a high and low fitting so you can blow out the water and drain it completely.
Reactions: Able 1
Alpine Utah
Jefftry Tobian
Yes it is 220 and a 4,000 watt Heater It has a big fan to get the heat through the boxtruck. When I get to my job , I turn on this heater to keep my truck warm while I am inside talking to my customer. After my truckmount runs for a while I can turn it off
