Scott S.
- Feb 3, 2008
- 3,252
- Name
- Scott
We were just knocking this job out super quick so i didn't even setup the seal a door. The cool air coming in felt great though.
the Direct drives arn't hindered so much by the outside temps like air cooled tm's are. granted if you have a huge tm engine you wont have to worry so much. But i know my Rage will dip a bit in colder weather. mainly because there is alot of cold air blowing accross the engine, heat exchanger, exhaust pipes, water pump, water lines, etc.Still haven't tried dualing but we did clean about 10k feet yesterday with the machine set on high. Sustained 230 in 35 degree weather on a 250 foot hose run and the cgd carpet was dry in about an hour. Still impressed with my pro 1200
Saiger" data-source="post: 4410184" class="bbCodeBlock bbCodeBlock--expandable bbCodeBlock--quote js-expandWatch">Both wands of mine are 8 flowWhat flow were each wand?
Someday might have to do a dual wand attempt for carpets.
Have done upholstery, but all my tools are high flow otherwise.
your apex has a large liquid cooled engine, so it wouldn't be affected so much like the air cooled motors.My Apex has been holding 230 all the time it will go to 240+ when doing upholstery(when I forget to put it on medium ) .. This is with the 165 degree valve in the water box.
