Dual Wanding with the Pro1200SE
Scott S.
PA
Scott
We were just knocking this job out super quick so i didn't even setup the seal a door. The cool air coming in felt great though.
Chris A
OH
Still haven't tried dualing but we did clean about 10k feet yesterday with the machine set on high. Sustained 230 in 35 degree weather on a 250 foot hose run and the cgd carpet was dry in about an hour. Still impressed with my pro 1200
Scott S.
PA
Scott
the Direct drives arn't hindered so much by the outside temps like air cooled tm's are. granted if you have a huge tm engine you wont have to worry so much. But i know my Rage will dip a bit in colder weather. mainly because there is alot of cold air blowing accross the engine, heat exchanger, exhaust pipes, water pump, water lines, etc.
Chris A
OH
My CDS is. I get a 30 degree swing between winter and summer cleaning temps
Chris A
OH
I think cold air through the vac hose really kills the heat too on tms with a blower exchanger
Reactions: D Luke
Grand Rapids, MN
What flow were each wand?
Someday might have to do a dual wand attempt for carpets.
Have done upholstery, but all my tools are high flow otherwise.
Scott S.
PA
Scott
Both wands of mine are 8 flow
Reactions: Mark Saiger
Able 1
Wi
Keith
My Apex has been holding 230 all the time it will go to 240+ when doing upholstery(when I forget to put it on medium ) .. This is with the 165 degree valve in the water box.
Scott S.
PA
Scott
your apex has a large liquid cooled engine, so it wouldn't be affected so much like the air cooled motors.
