Smelly waste tank, I use this.
Scott S.
Scott
If you are doing a bad pet urine job, or sucking up nasty greasy water, use this stuff. add a few ounces before or after your done cleaning. I use this alot and have a 1/2 gallon in each van. Why? because i hate the smell of urine or grease in my van, and it also helps deodorize your waste tank even after you drain it, until your next waste tank clean out day.
I use the orange scented one. Just thought i would share.
http://www.amazon.com/Camco-41507-E..._UL160_SR128,160_&refRID=15PKZD9KKSKZ8Y2SC660
D Luke
Derek
Thanks for the tip. Will give it a try.
One draw back about the 1200 SE - the waste tank gets extra smelly really quick. Worse than any other unit I've used. Not sure why.
Scott S.
Scott
i havent noticed that, have you rinsed your tank out lately?
Scott S.
Scott
That's is a great idea! Only problem is, it will leave me with nothing to blame the smell on after I pass gas. :eekk: :dejection:
blame it on a air bubble in your tank.
or do like some do and put the hose up to your rear when your cleaning and suction is on.
Reactions: Kellie Hiler
Scott S.
Scott
they sell the rv stuff i showed in the link at walmart.
our waste tanks never stink as that would piss me off.
dump every day and wash out at least 1 a month if not every couple of weeks with the truck parked on a slanted angle to promote draining.
Reactions: Todd Millar
Kellie Hiler
Kellie Hiler
I'm always afraid the customer will walk by just as I am doing this! :shifty:
Scott S.
Scott
yep thats the way to do it, i do mine once a week, i fill it clear to the top once, then let it all drain out, then run water into the tank to help get the sand out.
Scott S.
Scott
just pretend it got away from you and stuck to your pants.
"oh my, sorry its so powerful", if its a dude customer your fine, if its a chick, well she wont be impressed. haha
D Luke
Derek
Yeah, and I always run an in line vac filter to keep the sludge to a minimum.
With previous machines I was able to get away with rinsing the waste tank once a month at the most if I always ran a vac filter.
Not so with the 1200.
Scott S.
Scott
maybe its because the tank has such a big flat area for stuff to collect. My rage tank has a small bottom in it so as your draining it, the water flows faster accross a smaller area.
could always fill it part way with some sanitizer and drive a like a maniac, start hard, stop hard, swerve, etc to mix it all around when you do your monthly rinse. :) "no mr officer i wasnt drinking, hiccup"
Reactions: D Luke
Kellie Hiler
Kellie Hiler
I had it attach right dead center boob once and had a hard time pulling it off! I was seriously praying no one would walk by!
Female carpet cleaner problems......
