Operation tips for T-rex
Mike Raimer
Ludlow, Illinois
Mike
I just got my new t-rex yesterday. I have not used it but its sitting in the living room to my wife's disapproval. I was curious what the operating instructions are as the manual is vague. When do you use the speed adjustment, what pressure and temp, can you use it on berber carpet, and anything else that those with experience could impart.
Thanks,
Mike
IL
Thanks,
Mike
I have a 360i and run it at 300 to 350. The highest psi I've used it at was 400. Do you know what flow the jets are on the trex?
Speed, I always keep on the highest. Unless it starts bouncing around.
Yes, you can use it on a berber/looped carpet. Yes, it could rip berber to shreds if it catches a loop or something. I avoid it on a berber for that reason. Be careful around vent holes and transitions, etc...
New stuffs great! Good for you, Mike.
Tell the wife she's not the boss of you... They love it! lol.....:rockon:
be very careful of the aggressiveness of the vacuum shoes around open seams, transition strips, heat register covers etc. The Trex's shoes are like a southerner's teeth.
with any RE don't hover over seams, in could condition or not. The extreme heat can melt glue, assuming you have a good truckmount.
Reactions: Mike Raimer
The 360i says slow around edges and metal or tile. I used my hoss on Berber I dont have a high flow kit worked good. Like Mike said adjust speed depending on the smoothness if it's bouncing slow it down.
Russ T.
Slater, IA
Russ Terhaar
Yes, have used a 175 extensively. Don't have issues with the side by side action. Never tried another rotary, first one
You shouldn't have a problem. Hose management and cleaning patterns should be your immediate focus. I've never used a T Rex but I know what rotary extraction does for your overall level of cleaning being accomplished.
Stick with it. It takes real practice to get your speed and quality up. It's worth the practice. If you master it, you're competition should run and hide.
Boca Raton
I only used it on high and never had any problems. It cleaned and left the carpet very dry. You can run it right up to the transitions if you leaned it up on the front. Just be careful any mistake and instant damage. Most guys probably use a wand. I used it on one very weak Berber seam and it didn't hurt it. I didn't have the heat I do now. Depending on the size of the room it will be seam free so try it. I think you'll be very happy. If he didn't change the trigger release I would wire around it.
Reactions: Pioneer Floorcare
Work your way into the room, hose management and cord is the pita... You know how to swing a 175, so it's nothing to it... I tend to break the room into 4 sections and dry passes before moving to the next area... Keep the unit going till you come out the room and on to the next... I like to eat spaghetti, not have my hoses and cord act like it....:lol:
Mike Raimer
Ludlow, Illinois
Mike
Change what about triger release?
Mrice
Fl
Mat
Eliminate the safety or just put some black silicone so that it holds it on. Also get some tarp bungee balls, use 5 or six to tie the hose, solution, electric cord together, much easier to manage.
Noble Carpet Cleaners
I run the Jr. highest speed as I did my rotovac. Bout 375-400 psi with 150ft of hose. Certainly be mindful of seams and tile edges and vents etc not just on loop but any carpet for that matter. For me, the agitation has been higher then my RV but less then my RX. Helpful to have on hammered open areas.
Boca Raton
Listen to Mat he runs one every day. I didn't like the safety , I felt is was very uncomfortable to use.
Mrice
Fl
Mat
When you get close to marble, tile or wood transitions slow down the trex speed to it's slowest speed. It works fine wide open, but slower you go the more it extracts (obviously), it works about as well on low speed for extracting OSR urine spots as a water claw...and you can cover a lot more ground. If you have a spare 13 inch pad driver you can take three lengths of aluminum channel and mount them to the top so that they fit over the t-rex feet...cut them to length so that they touch the center brass hub and the end of the inside of the foot. This is by far the fastest way to pre-scrub. Much of this other t-rex owners helped me figure out. The flex head is pretty awesome on CGD and other short napped carpet or rugs. Twice I've pulled up a little carpet, both times were per-existing problems...one was a "repair" someone made with super glue...the second was a large patch that was not laid down properly...if you're worried about a spot just slow down and don't hover over it. I use about 400 psi and then use the thumbscrew on the trex to increase or decrease flow. It's very versatile. It does have a tendency to drool when moving it from one room to another, just burp it (break the seal on the carpet) a time or two and give the vac a sec to pull the extra fluid up the tube, otherwise if you fishing and leave it upright on the carpet and pull the hose of dirty water will drain back on the carpet, all our tools do this to some extent, once you're used to it, no big deal.
Mike Raimer
Ludlow, Illinois
Mike
Can you show photos of the pad driver modifications.
Mike Raimer
Ludlow, Illinois
Mike
Forgot to upload
Mike Raimer
Ludlow, Illinois
Mike
I have seen others that cut a small section and place it on the machine with a quick cuff. That is what I plan to do here in a few days. Waiting for temp to warm up and going to try out
John Olson
Orem UT
John Olson
Never ever ever bypass any safety especially the dead man switch. It's there for a reason. Doesn't matter if you never ever have it happen. I've never had my truck pop out of gear but I still use my emergency brake...I have however l slipped stripping and wAxing and gone down if if not for the dead man it would have been ugly. Same with your rotary. If you trip on our hoses you do not want that thing taking off on its own.
Mrice
Fl
Mat
John, if you were to slip and trip on a hose with your mytee trex, the only way it's going to keep going is if you are still holding down the "throttle" handle. The "safety" we are referring to is the double thumb switch that you have to push before you pull the spring loaded handle that turns the unit on. There is no way for an out of control machine.
Benton KY USA
Also keeps it from being inadvertently started by a child or other person who shouldn't. Most newer buffers also have such safety interlocks.
Mrice
Fl
Mat
I ran out of aluminum channel that's why one is short. The other two fit snugly between the outer trex and the brass inner hub, if that makes sense. PS this one works fine, but if you can get one with short bristles.
Boca Raton
he may have changed it since i tested it. the one i tried was a beta model . unless you had enormous hands it was very difficult to use. the spring was also way to hard to push. totally impractical the way it was set up. i tested it for a couple of weeks and it made my thumb start hurting.
