Tile cleaning children's book
Mikey was hired to clean a dirty floor.
Mikey always does the best job possible so first he swept the floor with his Direct Mops Sales .Com dry mop.
KqzbDvSe6MaY9I6iv5-qYTh5EgM-3jd2HTRaei-wF9C144CPuwruw3X4DXKo1TWf4x_yR4iu9VQMj2HxeUR=w560-h995-no.jpg
Next Mikey filled a red bucket wiht Sapphire's Versa Clean Eco Friendly Powdered Tile and Grout Cleaner and poured it on the pretty Travertine tiles..
Zn7-OSnTZRSIvmYA_P6XzmDW5LbfcIqD98xtI5zhKmj1ngkft-z9iTVHAHCxOALFbJfnSt0c2o4gn6LFmw=w1769-h995-no.jpg
Then anal retentive Mikey used his non communistic Brush Pro 10" scrubber to get the solution deep into the nooks and crannys. Just like how he cleans his belly button.
P2ZJbGx12RgRSILCLZTgefUCMma-hHcyEMfpSRq7UFP5MBldSd6dNyy9L9SVucB0wh7d0L6JNo0zMbt2OO=w1769-h995-no.jpg
The non communistic scrubber even gets between the potty and the wall.
v_CPeg8bA-dGfPXZc3aGnwVeCroPay8ODSc5TZ42lXGblVLVHqPXzPfcWHqYwQgUPq9Mtr15kOYWqrdqUGL=w560-h995-no.jpg
Mikey loves his PMF hard surface wand in tight bathrooms..
K4HBj-Pbrwa2UVqbx4AkYM0CK1a5B3S8clz1n7jacXcLIqcVKtgZaLb28n8O-l5IrIYPv4n3xjTQsgJBLRP=w560-h995-no.jpg
Try this with a spinner tool says Mikey..
tBBSSj93TTj2N08cg4_kxCVXXlX3ex_VjY36dW_FbO4a0OrHRBKgCY5dARhZgm4axqnFXrZBC9oilXYbAs=w1769-h995-no.jpg
or this..
38e1NQQz2A_97-3o0LFb2jtd4yEuq8yf2yPhRp_N9rN5Mw5iX1gnAeTW_zQVU-v5vzganKOJTz-JmZpaTv=w1769-h995-no.jpg
or even this..
S7KNRPsBIxigY7YAu-ocBsOteNbfmwzP4_UaFKHLTA1rspv_rIrBRNGYa5o2Hyj0N-yL1SbhiGM1NAhq72=w1769-h995-no.jpg
get the point?
eWCrJuezcPfTcR8-ZBZVkGdvkLjzjVzC46CPe5YkgKdwij-fIjkAmyvUpPwHjRg-eFUBgGHFAp_pltmlWh=w1769-h995-no.jpg
Mikey LOVES his two sided toof brush for digging buttwads out of corners..
WroJai3HD_6XqpWo2OijuusmraEfyOLVeB9wNflZkWMUm0bjiNO7Vc4GC7MnjrxcSHDyAVd3c243pWsosf=w1769-h995-no.jpg
After Mikey' rinses the floor he places his Dri Pod fans down to dry the floor.
OYWPLunof6vNEFXHRxEge54q3Iv5nNM7DkU6kK0QqpKgmaoy6JTPYKwRx9ElTDD74koo4oqra3g0XvY95M=w1769-h995-no.jpg
Mikey also tested a new liquid tile and concrete cleaner on this slate floor. Slate is Spanish for "rock"..
fxommGndAETvgPuRGd43Mbf1F3n1Egr_bB-APN82JDm5xYiikubRKNHOj2jA_u38gTxB-lvkqqHmLx_aUA=w1769-h995-no.jpg
Mikey was blown away over how clean the rock came out...
RfihBbVnyZ1-xo0xXbqkLKNvIt1cpS9IYCuEZISqdqA-QfeYsLVeBaTtDjEwq9lGm1hPKzehcKRQGpIzqo=w1769-h995-no.jpg
Mikey was taught by the great Bryan Tompson to always pour his solution down and not to use a 200 psi sprayer like that idiot who makes all the youtube videos.
YJx2Li-aeT1XM3EEVAl_P24XLoaSUhdLGtxO_amITNaV_JD_b4yEC2hGKpZhcJzBevnH2Zl7D7PUoOjz8Z=w1769-h995-no.jpg
That way you wont get the furniture or Clifford wet..
TGYh0BMWSfNrVZ5IexAjfUz-zZQu1HIm5VrvAxG0D4EAZUNwDAg58pPeL2saqWNrsoOjAsX9zbQGkjvRFy=w1769-h995-no.jpg
After Mikey rinses the floor and puts down his fans, he take a big thick and thirsty cotton towel and mops up any left over water so everything drys quicker.
T-tE9YL3c7c5xBmFCuIlklz6VllqMN0QZ-XvZr8UzYlZ0-TNZFYw6-Q66j2ysaLAFRR4BUbV1Y1QcgxzJs=w1769-h995-no.jpg
ATwwMqVnIcBWRYy-yW2Bp76s0j2SdqY63WEny6FwpeMW6JSTDF39wcGRQcmicypFX4faywltVYh_h9lo2r=w1769-h995-no.jpg
While the floor is drying Mikey makes good use of his time and packs up his big truck. Mikey has way too much stuff so the floor was really nice and dry and ready to be sealed..
Instead of sealing each grout line and wasting time that nobody on Sesame Street wants to pay for, Mikey just pours Cobbs (smells like Cotton Candy) down in the middle of the room and mops it in.
Absorbent areas like the Rock get two coats.
HBU8sTVCIHWqtblbF5xWiVQSBURf1zPUTKBnJU6EQVjDyENJA1Xj23f0gAXmDGMb45Gds3sDUqc9NT_na-=w1769-h995-no.jpg
Clifford told Mikey's that he did a lot better job then that last goodball.
7MHANRAbvQDYJzbgZmKS9C96STIyio7ialMG94-eNUsEC__RvW6fV1MUgtVvQYow1BYTS-VC0_KsCkRBLm=w1769-h995-no.jpg
Mikey was so happy with how it came out he went to the KTM store and bought a new dirt bike.
The end.
MLPW
I've only cleaned ceramic tile and grout. Cooincidently, I have a travertine job coming up, and they want the shine to come back. Would this be the process I need to do?
Zee
SoCal jungle
Simple answer: No.
Cleaning and applying sealer does not and should not make natural stones shiny...you need to polish them. That is a whole different animal you're after...
Zee
SoCal jungle
I would recommend acquiring a few sqft of several different stones and lay them on some garage floor or on pallets. And practice at home, or at your shop with different polishing techniques. Don't show up at someone's house and try to learn on their floors what not to do...
Reactions: Captain Morgan
Grand Rapids, MN
or this..
or even this..
get the point?
The end.
I like your 2 brushed tooth brush there.....Home D?
And that hard surface tool....guessing 2 jet? (I have a 4 jet hard surface tool) but just curious of the inside and what type of jets....
Thanks!
Matt applying a polish to Travertine is a skill that you'll want to learn through a class or being shown by someone with experience.
Each floor is different and the variables are such that It would take me two hours to type it all out and still you would not be prepared.
Posting a photo of the actual floor here would help. Sometimes you can luck out and all you would need is a 175 and some diamond impregnated pads..
Things to look out for; lippage (uneven install), sanded grout, topical coatings, scratches and customer's real expectations..
If you're real serious about offering more stone related services you should consider attending this class in April
http://mikeysboard.com/threads/mikeys-fest-at-stone-pro-in-anaheim-april-4th-6.281837/
Home Depot, ACE...just about all hardware stores have them now. I like the brass option over the steel or plastic. You'll be amazed how often a stain in the grout can be simply "brushed" off... The snout is so handy for digging Martys out of tight spots, you'll also be amazed.
4 jets on that wand and I honestly don't know what size. Works great.
Reactions: Mark Saiger
Grand Rapids, MN
Thanks....I really like the brass!
I am going to have to look for those!
Been using rags, plastic brushes...fingers....spatula types....to dig with Marty... :)
Would love to see the inside of that wand with the jets hose coming into the back (mine are on top)
Willy P
Vancouver
Willy P
Because of his miniature doodle, he needs to compensate.
