Jewelry store vlm
Prattville, Alabama
too small for the Cimex and my CBM is broken, so I brought out the pads and 175. I used one of Ricks products. The one with the green label ... Punch ... I think. I was pleasantly surprised at how well it cleaned.
But I had an asthma attack and had to use my inhaler!
What do mfgs make this stuff so irritating?
I agree shower feed is best. You get it in the airstream and it makes you cough.
We use a 15 inch Cimex for small areas. It's spins a lot faster but as long as you don't lay down too much solution you're ok. Otherwise it throws it around. :errf:
Rick J
Ohio
rick Jones
if I were Rick, I'd Punch you in the throat as well.
My 175 has shower feed , but when using abonnets I don't ue it. Only when using fiber pads.
Marty, when he saw where the shipment was going he mixed up a special brew!! lol;);):)
seriously though, shower feed is the way to go with pixie juices.
encapman
St Petersburg, FL
Rick Gelinas
Hi Marty,
I'm glad the job turned out well. But I'm sorry to hear the spraying application bothered your throat. We normally recommend using a coarse spray-tip for spraying any cleaning product. In the range of an 8005 jet works pretty well for pre-spraying. A coarse tip helps to prevent the spray from becoming too finely atomized. Shower-feeding is most effective for the "shampoo" style of encap cleaning. On the other hand - when applying a pre-spray, or when bonnet/pad cleaning - using a coarse tip should do the trick.
I'm happy that your cleaning results turned out good!
I miss the tea tree oil fragrance.
Messed my sinuses up but I really liked it.
I guess I'm going to have to start wearing a vapor mask.
Make sure you or your son are using good technique too. Keep it low to the carpet, we all tend to shoot from waist level which just adds to the issue of aerosolization of products.
Try the large spray tips, maybe a longer lance and then just keep it close to the carpet.
Reactions: Old Coastie
Ne
Helped someone do the same thing. Was hard to convince him that he didn't need to drag 300 feet of hose in a mall. Vacuumed, sprayed and bonnet cleaned it real quick.
I didn't know they had actual jewelry stores down there............you sure it wasn't a pawnshop?
Shorty
Cairns
Shorty Glanville
I really know where you're coming from on this Marty.
Those tight areas in joolrey stores can be a real PITA.
I do some, customer service areas, behind the counter & office sections.
Some of my other jobs get a bit dirtier than the crown jools.
  • Cimex Encap_manual.pdf
