say it Marty, SAAAAY IT!
Do let me guess Marty is try a a 360i with a brush head???
How do you like it Marty I've used Rx20, rotary dry master, 360i and a Hoss still need a high flow kit for my hoss and now a brush head god my 360i.
I still would rather have a 10 crb.
Breaking it in would require either use of a screw driver OR more time using it then he's owned it for...
I should know better to even ask.
rick imby
Montana
Rick
It's way too aggressive. We cleaned a commercial nylon Friday that we basically ruined. I tried everything and couldn't remove the swirls.
You were suppose to pull the lever to squirt water onto the carpet while you were cleaning with the brush head. It is not just a vacuum with brush cleaner.... Try not to leave it running in one spot while you answer the phone...
