What do you use for agitating your pre-spray?
What's your go to tool for agitation?
  • Total voters
    36
I only run if someone is chasing me, other than that HELL Naw!!! Those that run for the sake of running are running from something...........:winky:
J
Jeffrey Tobian
I also carry a santaire vacuum in my truck
Zee
Both of those you showed aren't really recognized as good at vacuuming stuff up.
At least I don't view them as such....
A Sanitaire not good at vacuuming?
As long as the belt is tight, they are excellent.
Unfortunately, 80% of the belts stretch out and or crack or break within a few rooms of use
They really need to modify to a flat belt like the Royal /Kirby.
Zee
Like I said, that's what I see..I never had luck with the sanitaire...even with a fresh new belt I always felt that a cheap bagless will pick up more fine soil and hair.
Just did 6000 sqft today on my own. 4000 just prespray and extract, 1000 prespray, crb and extract and 1000 prespray and crb only. Total time on job, 5 hours for $1,200. I am mightier than Chavez, except for the smell. Must be all the manure he spreads. Old pump out worked well.
Nice try Stinky! :biggrin:
Hell boy, I coulda cleaned that in an hour. :shifty:
6-Cimex's bungee'd together with furring strips. A dowel rod tied to the solution control trigger. (Fook MacGyver)
From right to left every other machine rotating the opposite directions for maximum control.
Don't try this at home, mere mortals are not capable of such a feat.
Fortunately I AM MIGHTY. :cool:
Ron you get an "A" for effort but shower up....yor "B.O" is mighty stinky! :winky:
Nope....carpet. :eekk:
I believe it was that way prior to my arrival. In fact I'm positive of it. :headscratch:
Josh
Josh
It's a turd....... Good for stairs if your a cheap ass like me and don't want to fork out the coin$$$$ for a 10" CRB... Although I do rarely use it anyways.... I figure I have a RV360i and can use that on the stairs that really need it... And I also got one of those shitty Oreck Orbiters, another turd..... The guys who recommend those tools don't have a RE they use... I learned from a young age (9yearsold) that the wand is for the birds....
Oh yeah?! Then how about THIS?!!!......
Reactions: Mike Pailliotet
I try not to make a career out of scrubbing a carpet... Cimex it and be done with it.....:lol:
