- Feb 4, 2016
- 14,637
- Name
- Matt w.
If so, what are your dry times and what psi do you wand it at? I currently run 7.5flow, and I'm thinking about bumping it up.
I have 5 jets as well on my mach15. I never liked a jet under 2 flow, and I feel the 1.5's aren't rinsing out as well. I've never been up as high as 10flow, and I was concerned that my 4007blower might not be big enough to extract that much water at 500psi. How big is your engine and blower?5 number 2 jets in wand for 10 flow with 3/8 inch solution hose and kerosene burner.
12 flow with Rotovac 360i quad. Four 1.5 flood jets.
Always do a dry pass.
20 flow on a 5 jet Greenhorn. Heat is not a problem with a Diesel burner.
Sufficient dry strokes, and it won't be a dry time issue either.
It was the first must have wand that Mikey loved.what the heck is a greenhorn?
I agree on the jets clogging.I have my 13" Zipper jr setup with 5x 02 jets =10flow and my PCTI wand 6x 02 jets= 12flow... 20hp Honda motor, 45 blower, #4 Little Giant Heater... I've put 03 jets on my Zipper jr for 15 flow... Worked good but the filling of the waste tank sucked with I'd have 100sf left... I dropped it back down and the only difference I really see is how much thicker the waste water is than the 15flow... 1.5jets clog too easily for me...
No kiddingJust do it.
Then you can lie about your drying times too.
I always told my customers dry to the touch at 4-6hoursNo kidding
Some of you goobers need to clean your own double wides and take a moisture meter to it after 8 hours
Lots of cleaners lose credibility with their customers telling them it'll be dry in a couple hours
Are u trying to hack up a loogie?Hack
