How much time to encap 27,000 sq. ft. office?
jawhit
Joe
How much time would you estimate for encapping 27,000 sq. ft. of office cubicles (including vacuuming)? I going with 3 guys and 2 Cimex machines. The carpet is in good shape, just maintaining it.
27k /2
13.5 /900 sq/ft
15 hours
Cubes are slow you might be able to squeeze another 100 or 200 sq/ft and hour but its nothing like open areas.
We would likely run 6-Cimex's and get it done on a Saturday AM. :winky:
I figured that was what the third guy was doing. ???
We have jugs like this filled with water. We drop them off throughout the facility so then you just refill quickly and easily.
encapman
Rick Gelinas
3 guys 2 Cimex's:
Third guy pre-vacs and gets water, etc.
Each Cimex averages 2500 sq ft per hr.
Two Cimex techs = 5000 sq ft per hour.
You should be able to knock out 27K in about 6 hours. Round that out to 8 hours and you'll have plenty of wiggle room. All three techs have to hustle though to pull it off. Otherwise you'll need to add an extra hour or two.
jawhit
Joe
Thanks @encapman that was asking the lines of what I was thinking, but was just wondering how much you might take that down based on it being cubes.
Good luck. I agree for open spaces but my experience is cubicals will slow production to a crawl.
Reactions: J Scott W
encapman
Rick Gelinas
We've got a pretty quick system for cubes. Run the Cimex into the cube. Let go of the machine. Grab the office chair and pull it out. Shove the Cimex under the desk. No need to worry about network cables; it won't grab them. After scrubbing under the desk, pull the Cimex out. Swing the chair back under the desk. And scrub your way back out of the cube. It goes prett fast. Only takes a couple of minutes per cube. Faster than a swing machine and safer around wires and cables.
There have been times when I job costed and got a pain deep in my stomach. Each of those times were when I over estimated production times for cubicles.
They never listen. :dejection:
I've got 45+ years on 175 and their 320rpm cousins, the Cimex is not faster.
It IS "chimp-friendly", if that's what you hire.
Reactions: TomKing
We love the Cimex, and any cleaner should have one. Fortunately with a variety of tools you will find a niche for each.
encapman
Rick Gelinas
Like I said, YMMV. For me I think it's drop dead simple to shove the Cimex underneath desks. You can let go of the machine, while it's running, to move chairs and other stuff out of the way. I agree that a rotary machine has a slight degree more agility than a Cimex has. But that comes at a price. Firstly, the rotary machine will wear your body out on a big job, especially the size of the one described here. And a rotary can also gobble up wires/cables, whereas the Cimex will just spit them out. On top of that, the Cimex has a much larger tank. And lastly, it scrubs more thoroughly than a rotary machine (the Cimex spins at more than twice the speed of a 175 - and it's rotation is planetary rather than rotary). For my money, a rotary doesn't hold a candle to that.
A 20" buffer has 316 sq inches of contact area to the 151 sq inches for the typical Cimex, and the actual edge speed is also greater with the buffer
which somewhat negates the increased rpm of the individual cimex pad.
Tank size is similar, at somewhat over 4 gallons. You are right about the brute fatigue, but it CAN do the job very well.
Reactions: TomKing
