Cool Cuffs to Flash Cuffs
jawhit
Joe
I'm thinking of switching from Cool Cuffs to Flash Cuffs. Anything I should know or think about before switching?
gtech12v
Go try any other copy (links, flashes..........) ,I know already you will come back , cools coming undone some silicone takes cares of it
Reactions: dealtimeman
Bill Soukoreff
One of these days I gotta make the switch over to flash cuffs. Can you get male starter 2.5" cuffs with NPT threads?
I have dual 2.5" ports off the Butler filter box connected to a 2.5"wye.
Doug Cox
Doug Cox
I did the same years ago.
My guys we fed up of the Cools coming undone on our electric reels. Dangerous as its too likely to get a cuff to smash your nose back into your brain.
Flashes leak air a tad so adjust your vacuum relief accordingly.
Totally agree. I asked Mike before I switched and am happy with the choice. Better than Cool Cuffs. Noticed my first cracked ring on one cuff today.
You have to replace the first few leads sets very so often if you bang or drag them around
....Big deal.. $9.99
Bill Soukoreff
The 2.5" cool cuffs come apart on the reel almost daily for me. Real pain. Other then that, they have last several years. Ready to switch to Flash.
My Cuff-Lynx experiment was like burning money. Hard to believe those are on still on the market.
D Luke
Derek
Flash cuffs are great. No complaints at all, just be to replace the heavily used ones once or twice a year. Worth every penny and more.
If you wind as slow as you talk it's no wonder..
I know you're too thrifty to buy an electric real... 'Dats wat youngins a'r fur!"
Mikey, you should think about doing a hose coiling contest at Nashville. Judging on speed and style. 70% on speed 30% on style. I'll put my money on Lee S.
Cool cuffs were and still are the best can't Stand footballs along the hose run no bumping and getting caught on everything.
I've had a set or two of cool cuffs break and joe replaces them. Good fast service is hard to beat
TConway
Thomas Conway
cool cuffs are very good, but on 2.5 you cant beat flash cuffs they dont unscrew, I got fed up with the 2.5 coming undone on the hose reel, it sits under my first 75' of 2" and I don't know why but the cool cuffs would come apart and make a very big mess of my hose reel. So I switched on my 2.5 hose and the flash cuffs have worked out fine.
Reactions: J Scott W
I've never had a problem with Mytee cuffs. I don't know if those are the cool or flash cuffs. I've put well over 1200hrs on my Mytee ones and they hold together just fine with no leaks. The trick is to turn them counter clockwise until it acts as a spring to twist itself into closing position when you want to connect them.
And always, of course, use some sort of silicone sealer to install a cuff on a hose for obvious reasons, duh
