How do you like your PIE?
SAIGER SAUCE 1 Bring on the Blue !!
Okay back to the topic at hand
:biggrin:
Reactions: TConway
Did you know the using a brush head rotovacs allows you to turn the pressure way down?
and the results are waaay better
And faster?
Same thing if you pre scrub and than wand
Im not to old or stubburn to learn
Bob better not be either.
What's interesting and I'm was in this same boat for years.
We believe that some how the cleaning pie is separated Heat, Time, Mechanical, and Chemical.
Removing one and adding more of another will get the same results.
A Truckmount has high heat so less time less chemical less scrubbing.
The idea is We pay 50k to 100k for a Truckmount its got do more than a Vacuum, or a 175 ect. ect.
So we justify running in pre spraying and steaming and doing as little as possible.
Most skip the vacuum skip the scrubbing thinking this is as good as it gets. Some even skip the pre spraying.
Reactions: Bob Pruitt
Bob Pruitt
Robert Pruitt
? I'm not going to be a hack cleaner! I will take every advantage I can get. I wonder why the other RE tool guys haven't come out with a 1/2 horse power tool with brush head? Maybe we will see that in Vegas? Zippers... oh, yea!
? I'm not going to be a hack cleaner! I will take every advantage I can get. I wonder why the other carpet spinner tool guys haven't come out with a 1/2 horse power tool with brush head? Maybe we will see that in Vegas? Zippers... oh, yea!
They're coming, trust me...
Ask George, Rods retired. My guess 1.5 lbs clean green 1 cup ultra pac 1 cup liquid pro
In a 5 gal pre mix
Set to meter at 10 last time I checked.
Jefftry Tobian
If it is oily add citrus-sol , if it needs brightening add OSR. If it looks pretty good use a low ph prespray, vacuum, scrub, clean and then rake it is not rocket science
