FelsApalooza
My guys love it..
Blue Monarch
Dirk Wingrove
I can hardly believe it when guys don't like using it. Definitely my go to product.
Zee
People that don't like it.... either have something to sell or not on the field actual operators on a daily basis.
Or snobs... That would only use what some self proclaimed chemist would sell through interlink.. Oopsie
Reactions: Russ T.
It depends.
Normal guys just put it in a small carry on pocket, and rub on stains that did not come out with the wand, rinse very well and it does wonders. Just a great all around spotter that never (hardly ever) lightens the area, works well on all carpets and removes most stains.
Some make a cult of it and have some recipe that was passed down through the ages from grandma to son from Transylvania to the black mountain caves of Alabama.
Reactions: hogjowl
Russ T.
Russ Terhaar
Check your local supermarket. It's like .89 cents here at HyVee. It's a laundry spotter...in that part of the store.
A bar will usually last more than a month for me.
Kevin De Medeiros
It's not sold in Canada for some reason. The only place I've found is on Amazon.
I thought it worked well on filtration lines but haven't had a lot of success with it on many other stains.
Maybe I'll give it a try again.
Reactions: benjam99
Hacks! Fookin Hacks!
I weep for the destruction you do to our industry! :winky:
So how do you make it? lol
:shifty:
J/K
We are too snooty or is it snoty? :biggrin:
Reactions: Russ T.
I wonder If I got counterfeit bars from amazon?-- cuz using fels was a waste of time for us. went back to using CTI powergel.
Many times. I was better off applying more prespray, Or diluted Power Gel in a spray bottle.
I ended up using fels as a bath soap. I still have an unused bar.
Russ T.
Russ Terhaar
I like to get my prespray down, I use vac hose for edging to give some dwell time, and if it's a really heavily spotted carpet I walk the prespray area with the Fels.
It won't move EVERY spot but a little rub and some agitation (sneaker :confusedd:) and a little dwell time...I'm rarely using other spotters.
It's a great companion to this rotary extraction lifestyle :cool:.
A.J.
A.J. Hodges
I turned my wife onto fels for laundry and shes been amazed lol. I've chopped it up and mixed in hot water to clean sofas.
