FelsApalooza
My guys love it..
Zee
People that don't like it.... either have something to sell or not on the field actual operators on a daily basis.
Or snobs... That would only use what some self proclaimed chemist would sell through interlink.. Oopsie
Reactions: Russ T.
It depends.
Normal guys just put it in a small carry on pocket, and rub on stains that did not come out with the wand, rinse very well and it does wonders. Just a great all around spotter that never (hardly ever) lightens the area, works well on all carpets and removes most stains.
Some make a cult of it and have some recipe that was passed down through the ages from grandma to son from Transylvania to the black mountain caves of Alabama.
Reactions: hogjowl
Russ T.
Russ Terhaar
Check your local supermarket. It's like .89 cents here at HyVee. It's a laundry spotter...in that part of the store.
A bar will usually last more than a month for me.
Reactions: Mike Pailliotet
Kevin De Medeiros
It's not sold in Canada for some reason. The only place I've found is on Amazon.
I thought it worked well on filtration lines but haven't had a lot of success with it on many other stains.
Maybe I'll give it a try again.
Reactions: benjam99
Hacks! Fookin Hacks!
I weep for the destruction you do to our industry! :winky:
So how do you make it? lol
:shifty:
J/K
We are too snooty or is it snoty? :biggrin:
Reactions: Russ T.
I wonder If I got counterfeit bars from amazon?-- cuz using fels was a waste of time for us. went back to using CTI powergel.
Many times. I was better off applying more prespray, Or diluted Power Gel in a spray bottle.
I ended up using fels as a bath soap. I still have an unused bar.
Russ T.
Russ Terhaar
I like to get my prespray down, I use vac hose for edging to give some dwell time, and if it's a really heavily spotted carpet I walk the prespray area with the Fels.
It won't move EVERY spot but a little rub and some agitation (sneaker :confusedd:) and a little dwell time...I'm rarely using other spotters.
It's a great companion to this rotary extraction lifestyle :cool:.
A.J.
A.J. Hodges
I turned my wife onto fels for laundry and shes been amazed lol. I've chopped it up and mixed in hot water to clean sofas.
