thanks.I'm no Saiger, but I'll PM you..
Fookin Cowboys!They didn't like my tweaking the Little Giant heater trick either...![]()
I'm not saying it can't be done but seems very impractical. For a small job like that a decent high performance portable like a Mytee dual 3 stage with 500 psi pump will do just as well. You can get them with autofill/dump as well. To me the Dwell Pro seems more appropriate for large open areas where you can't get a tm into. Seems a little overkill for a small job.
I would be faster on smaller jobs with a smaller more maneuverable unit as opposed to that behemoth.
I agree.......the DP is a niche unit for large jobs where it can be run continuously with live AF/APO and long vac hose runs....that's what it was built to do.......to run such a big unit any other way seems counterproductive to me.
Well I guess it was a dumb ass idea... sorry I over reacted @anon Honestly thought everyone did this... so OK... you guys never do what I use to do!
I think it is all in what you get used to. With the Dwell Pro they are going to be focussing on getting different things than what you are focused on with your setup. In time some jobs will go better with the DP and some better with 12 gallon porty. Adapting is the key difference between Bosses and Chimps...
The DP was built for square footage production...not 2 rooms and a hall.
it was also designed to stay at facilities...
lugging those things around on a daily basis aint for the weak spined..
....bottom feeder"
You left this key part out.![]()
I'm excited for you too.
Bleh
You need a forklift to get your portable off the truck?
Just ribbing you, let us know how it works out for youNot sure how exactly it's being shipped. I suspect it's on a pallet, so we need a loading dock or fork lift.
It won't work.You'll be the first to run a Devaststor off a Dwell Pro
Could be a match made in heaven...
Big mouth wand?It won't work.
She talks too much.
I don't see the point of running a filter with it. Why? Just use a paint filter on the inlet inside the tank...or nothing. Just keep the small pump out screen clean.
Edit: I forgot that their hacking doesn't allow vacuuming.
You've certainly got your mind focused on all things butt related!True, with that machine in particular, pre vacuuming will be a must on piles
It was the focus in a room with just me and three cute nurses...let me gloatYou've certainly got your mind focused on all things butt related!
