- Oct 6, 2006
- 117,295
My guys like Gum Break from Interlink best. Can be Cimex'd over too..
$20 bucks for a long lasting quart!
https://interlinksupply.com/index.php?item_num=CS36QT
Whats your fave?
I do!!Who cares? They all work.
well, if no one else steps up, I volunteer. I have been described as such.!!!Guerkink does not make Hel Gel
Steve Smith does
We need an Idiot smiley.
TightwadWD40 in a duct taped over can, custom company black marker logo, and hold it at 45* and spray with red tube at base of gum and just watch it roll right off the carpet fibers![]()
Its very easy to use. Fast and effective. The best I've ever seen, its a time saver.Gum Up by Guerkink (Trinity Renewal) is the best gum remover I use. Vacaway doesn't have Gum Up. Not all of Guerkinks products come from Vacaway.
Gum Up is different than all other gum removers I've used. It's not a solvent and won't hurt the backing. The reason I think its better is you can just squirt it on the gum heavy when doing the walk thru then by the time you extract the gum is loosed so it comes up during the clean. Most of the time no hand scrubbing is required, just wand scrub it. It's weird because its not a solvent that dissolves the gum it just makes it not stick to the carpet fiber any longer. Truly a unique product. Doesn't resoil either like the citrus gel spotters do
Mikey;
Have your guys try StainSolv on the gum (side by side).
It will work faster and doesn't resoil , due to more complete rinseability.
Lots of customers like it for adhesive tape residue (Shawn Bisaillon , etc.)
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=65&products_id=5240
