The best 2.5" hose. Where can I get it?
I want a Red 2.5"to hook up to the first 50' connected to my truck mount with cuffs and I need to purchase a 2.5" 90degree angle connector for my waste tank lid also.
Who's got the source?
Because the ONLY reason to wrestle with that anaconda is if it offers REAL utility.
Just one 50' hose can't be that bad of a problem on setup. It's not like I'm going to be wrestling the hose. Besides, I'm considering using it only on jobs where I need 150' and over only.
Don't spend extra to get fancy stuff. It's only 50 foot off the truck, doesn't need to be super flex or anything special.
Always try Larry first for everything. You would be surprised how much you'll save.
Russ T.
Russ Terhaar
I'm going to 2.5" too. I've had 100' of it sitting in the shop for a year now.
Devastator Tom allowed me to swap the 2" setup I won in Nashville for a 2.5" version. It came in this week.
What's the best way to get 2, 2.0" ports from the top of my Cleanco waste tank to 1, 2.5" port on the Devastator?
Unless folks are complaining about your drying times, don't do it.
Why wait for customers to complain about your work, before you push forward to become a better cleaner?
:headscratch::marty:
jwfoulk12
Justin Foulk
I run 2, 2 inch into into a y that has 2.5 coming out the end. Got it from Greenie as well.
Reactions: Russ T.
Larry, will that plastic hose barb screw right into the lid on my Hydramaster's tank, or do I need something on the underside to screw in to the threads on the barb to secure it?
The pipe thread is 2.5" NPT (national pipe thread) on the barb and the elbow.
Most threaded connections on recovery tanks are 2" NPT.
If you cut a hole, then we have a metal 2.5" Nut that will attach it.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=68&products_id=4224
I know what the size is. But what I don't know is will it come with something to secure it to the lid? My 2"elbows that are attached have a flange or something like that, that screws on the underside, holding it to the lid. Do you have something similar to send with your barb?
