Words cannot describe!
This small little 600 sq ft house the cat urine smell is atrocious. Lady wants it fixed so she can rent it.
Appears the odor is in the Grout, I don't think it's in the wood or the lamenant wood have more edge lifting.
Any suggestions besides run.
Oh ya in case I forget Merry Christmas and Happy Holidays!
Sam, mop it with a nuetral cleaner, then immediately follow up with a generous application of Unleashed Unduz-it enzyme stuff. About $30/gallon from whoever sells it locally, but it is advertised on MB too.
You MUST douche out under, behind and above the baseboards. Expect a LOT UNDER THE CABINETS. Don't be surprised if the urine has run under the laminate and warn your customer.
It is good stuff. Good luck and Merry Chrismas.
What's the urine like light showing? Is it sprayed on the walls also?
Bob Pruitt
Robert Pruitt
Walk. or - Very high price with a no guarantee signed waiver. Nothing looks up to code and sadly, you know she is going to get really high rent out of that POS.
A
Able 1
Don't look past the laminate.. It can look great on top, but it will sit in between that and the subfloor!!
I moved the stove back and forth and out squirmed this feline up under the sink to only reappear in the drawer.
I knew a cat had gotten in since my last visit since there was fresh pee and a few dropping.
Used a gallon of pet stain off . Then dropped 2 odor control foggers are hoping for the best will go back
And check in 2 days
Reactions: Mark Saiger
