Where can I buy Teejets in bulk?
cape coral fl.
jack zerkie
Try Kleenrite car wash supplies they carry all the spray tips a large catalog . Prices are good I just purchased a new general pump at a good price. I found the info here on Mikey's board thanks to another member.
MERRY CHRISTMAS to all and Thank You for all of the wealth of info from THIS BOARD. jz.
Jack;
The General pump that Kleenrite sells,
does not come with Teflon(r) seals that most carpet cleaners need,
for long life and run-dry capability .
This product line features patent-pending packing, a valve design that can withstand high temperatures—up to 185°F!—and the capacity to run dry for several hours...
https://www.kleen-ritecorp.com/c-929-general-pump.aspx
What's the difference between the seals that come with it and "Teflon" seals you sell?
Dallas, Texas USA
The General Emperor Pumps (more expensive) ,
and the special ones we order come with Teflon plunger seals.
Just letting you know there is a difference.
Over application of FPA is a no no
Because it's so expensive? Or does it affect the carpet.? Are you using the 8001 on carpet or upholstery. Most water based protectors such as Scotchgard or Teflon use a 8004. For upholstery with a solvent protector, I use a electric airless paint sprayer. I keep a litre (quart) of oms in the truck and rinse it right away so it doesn't clog up.
Reactions: Steve Lawrence
Dallas, Texas USA
The new pump is the same # as the original but not with Teflon seals. Does the hot water go through the pump or just cold water ? jz.
Cold water, but the pump water will heat quickly from friction, when you are not spraying.
Just keep that pump spraying water every few minutes, and you will be fine.
J Scott W
Shelbyville TN
Jeffrey Scott Warrington
We can sell you as many 8001 TeeJets as youw ant. Around $6 each ofr the brass version. I could probably get you a good deal if you wanted enough.
