Where can I buy Teejets in bulk?
8001's in particular.
FPA has so much solids, it's plugging them up and the clean out process is a pita on site..
jack zerkie
Try Kleenrite car wash supplies they carry all the spray tips a large catalog . Prices are good I just purchased a new general pump at a good price. I found the info here on Mikey's board thanks to another member.
MERRY CHRISTMAS to all and Thank You for all of the wealth of info from THIS BOARD. jz.
jack zerkie
That would be nice I promised my wife this might be my last year time to retire 75 next month but I still love carpet cleaning and just might clean for the exercise and meeting people. I might want to help at the Mc Donalds house if you still need it.
8001's seem to be a bit small for fpa application. Especially for carpet. After use, try flushing with a little oms.
Reactions: Larry Cobb
rwcarpet
Robert Hodge
kleen-ritecorp.com Any T or Vee jets you can think of and most under $5 a piece. 1 or 100.
Jack;
The General pump that Kleenrite sells,
does not come with Teflon(r) seals that most carpet cleaners need,
for long life and run-dry capability .
This product line features patent-pending packing, a valve design that can withstand high temperatures—up to 185°F!—and the capacity to run dry for several hours...
https://www.kleen-ritecorp.com/c-929-general-pump.aspx
What's the difference between the seals that come with it and "Teflon" seals you sell?
The General Emperor Pumps (more expensive) ,
and the special ones we order come with Teflon plunger seals.
Just letting you know there is a difference.
Over application of FPA is a no no
Because it's so expensive? Or does it affect the carpet.? Are you using the 8001 on carpet or upholstery. Most water based protectors such as Scotchgard or Teflon use a 8004. For upholstery with a solvent protector, I use a electric airless paint sprayer. I keep a litre (quart) of oms in the truck and rinse it right away so it doesn't clog up.
Reactions: Steve Lawrence
The new pump is the same # as the original but not with Teflon seals. Does the hot water go through the pump or just cold water ? jz.
Cold water, but the pump water will heat quickly from friction, when you are not spraying.
Just keep that pump spraying water every few minutes, and you will be fine.
We can sell you as many 8001 TeeJets as youw ant. Around $6 each ofr the brass version. I could probably get you a good deal if you wanted enough.
jack zerkie
Try Kleen-Rite corp. They have stainless tips $4.61 -$ 5.12 each Large selection You can buy 1-or as many as you want.
