Key is the right balance of squirting and sucking!!
a Higher volume of solution , while seeming to flush well , does no good if not recovered.
Thinking YOUR nasty berber. That stuff can be difficult to recover the solution because of it's nubbiness., Also, it often is sculptured with patterns, that keep your wand up off the carpet ever so slightly.
Your TOOL, whatever it is sometimes does not recover efficiently because it can lose its seal to the carpet fiber.
And now to start some trouble! Try using some kind of VLM on that berber!!
Heck, just use some juice of choice in a few spot with a towel. Not overwetting.
Or maybe get your buddies to bend over, since they probably caused it.
Heck, just use some juice of choice in a few spot with a towel. Not overwetting. Or maybe get your buddies to bend over, since they probably caused it.
