Bane-Clene cleaning detergents are way underrated!
Stopped using Bane when I strait cleaning with water over 110 degrees
Also didn't appreciate getting a cease and desist advertising letter from them because I was using a Butler in addition to owning a Bane Maxi Mount, Megamount and dry cleaning unit.
Banes chemist states that most of their formulations are for Luke warm water.
The PCA5 'cooked' and was useless
They added chemical lines to boost slipping sales
Too bad they didn't add a truckmount to their arsenal... they'd be a force
Instead of a farce
I ran my bane hotter than this WM gets. At least the first 70 gallons.
But it would rain inside the van from all the steam.
FB7777
Oh brother, sounds like there is something wrong with your WM
Before I switched from Bane, I ran a propane heater with it
Had to change the solution lines and wands cause none of Banes stock stuff can handle 200 degrees
You're not one of those delusional BC guys that believed he was recovering more than 80% of the water he was putting down at more than 120PSI ATW?
If I wanded reeeeeeeal slow it would be pretty dry but I didn't go that slow normally. Took to long and too much water. Needed good electric too. Lotsa old homes around here still not updated from the 40s and 50s.
I switched valves over long before I stopped using the bane tools. Still using the stair tool though.
And yes I need a new heat exchanger but still getting 180 to 210 at the machine with one exchanger.
FB7777
How were you getting higher temps than 180/200 with the Bane?
Had to be fuel fired. The stock pump would have been junk at those temps
Best I ever got was 160 without propane
Bob Savage
Bob Savage
I also got a letter from the lady that ran their office to change the original name of my ETM or they were going to sue me.
I changed it.
Lee knows who I mean.
Reactions: FB7777
FB7777
Mine came from Oka Negley
She was Bill Banes ankle biting lapdog
Be a man and make a phone call
Cowards hiding behind lawyers
Piled bonnets on the cap and ran the electric heater all night. Nobody believes me but when the gauge worked it would read 220. Steam would be whistling out of the cap. Hoses and connectors would be to hot to touch unlike. The WM. But I had some days with. The WM that it got super hot. Before the exchanger started leaking.
FB7777
The worst smelling prespray I ever used was Bane TLS 2000.
I think that toxic concoction had a Judson ph rating of 15
FB7777
Back in the early 90s they were selling Paramount 120 gallon tank systems and loading them in Chevy G20 vans
They were overweight as soon as you added water to the fresh tank
Came with Load C tires which flexed instantly and the front end tires would scallop at 20k miles
Went through 2 seats of rear axle bearings before 80 K miles
2 years later they started installing in 3000 series
Dopes
FB7777
I had to add a leaf to the rear of my '88 E150 so the Mini mount would drain properly
Good times
FB7777
Couldn't use a filter bag or you'd have Barely Any Noticeable Extraction
A 2 inch dump valve would have clogged in the first month of use
jack zerkie
Pa Pa Bane had a great idea but the unit lacked vacuum& heat. He should have talked to Tim Allen on tool time and Tim would have boosted the whole unit to be like todays units. jz.
Rick J
rick Jones
That? He sends that picture to all us "Puppets" at least once a month.
That reminds me, Mike you really shouldn't swallow your chewing gum. :shifty:
:winky:
That reminds me--------- still looking for the best chewing gum remover!!!
I like to tell those customers who think it is easily removed(usually the ones with the most, old and ground all the way through)
Gee , you chew on it for hours , swallow it , goes through you and your digestion, it doesn't begin to break down, and you think a quick swipe will take it up ???????
I guess we all should be terrorists(hijackers) :biggrin::biggrin:
GeeeAus
Grant Baverstock
So is a Bane better than a modern portable?
Yes or no.
FB7777
What do you like about them?
What are you using for carpet cleaning now?
I ran them for the first 12 years of my business and then bought 2 Butlers to replace them
They are FAR from portable, heavy as heck
If you do decide to buy one, absolutely buy used
They are way overpriced brand new and would be cheap to fix if required
Just trying to give personal experience so you can make an informed decision
Reactions: GeeeAus
GeeeAus
Grant Baverstock
I should say I live over in Australia. So the van is more applicable to somebody bit closer. Second hand units sound interesting.
I have a hybrid setup built around a Nautilus MX3-500H portable. I have a KleenRite Inline Airflow vacboost so I can lift up a bit of vac drop over a longer hose. I can't have a TM. Just out of the question. Best I can hope for is a hybrid which I have essentially built myself with off the shelf machines and a little bit of modification.
I totally get this thing is SFA to you guys with engine driven machines and you are all really proud.
GRRRR.
But I don't hold those cards and I wonder if this hybrid is better than my hybrid? Or more if the vacuum system being positive displacement rather than fan based is better than my porty? Which is the heart of my Hybrid?
Thanks
Reactions: FB7777
FB7777
Got it
Don't let the fact that Bane uses a PD blower influence you, it's a 33 blower and it is severely under driven due to the limits of a standard 110 outlet ( less than half its capability)
The water pump delivers around 150 PSI MAX pressure
You will extremely disappointed with its performance
Don't buy one without trying one first, you have more power now
Reactions: GeeeAus
Instead of a farce
How can you have any credibility when you are preaching low heat . . .
and even lower pressure ??
An underdriven #33 is ridiculous at best . . .
Reactions: FB7777
rick imby
Rick
However with 220 volts in Australia could you put twice the powered electric motor on the Bane? And run it at twice the speed? I cannot imagine there would be a tank issue. Two 220 volt circuits should be able to make a Truely powerful ETM from a Bane Base.
