What jet set up would flush better
I'd rather go over the areas more than once with 300 psi than blast the poop out of them at 600psi.
95% of the time I'm 400psi with 02 jets.
What kind of heat is your 370 holding at 8 flow
Mine with my 9 flow 360i does well but the aggitator is doing far more than the heat.
Tony Wilson
Solvang, Ca. 93463
Tony Wilson
Running prochem quad w/1.5s at 400 psi. Seams good. Should I bump the psi? Should I go bigger? 4.8 blower so recovery is no a problem. Just always concerned about over wetting. I spray forward and bs k then double dry pass with slotted glide.
Ne
As far as child molesters they have to prove Marty was one first.
BUT HE'S NO DAISY!
I felt the .02 caused more fiber distortion even at lower pressure so I switched to .015. still get it but not as bad.
I may try them again, it's been awhile since I used them.
Bob Savage
Dayton, Ohio
Bob Savage
I clean at 400 PSI with 4 #02 jets on a 2" TI wand.
When the wand is keyed, the 400 PSI drops to 350 PSI.
When the second wand is keyed the pressure drops to 335 PSI. The second wand has 2 #9503 jets.
I have found this setup gives me great cleaning/flushing without over-wetting.
Ya flush hard with 1.5-3.0. To the 5 th power and 1-/2 inch hose
LARRY COBB
On Samiam's phone.
Oh ya that flow chart was @dgardner work peace.
Dallas, Texas USA
Spraying Systems has lots of jet impact info.
Double the GPM and you get DOUBLE the impact.
Double the PSI and you get 1.44 x the impact.
Most T&G cleaners are running two #0502 jets.
We have been changing them to two #0503 jets,
and seeing a significant increase in cleaning power (50%) .
Reactions: vibra-vacster
