Rotovac Shear Dry auction
Up for grabs is a new Shear Dry hand tool
    Dual Direction Spray Bar Centered Between Two Vacuum Slots
    3/4 Horse Power Version
    Fiberglass Reinforced Composite Body - Strong & Lightweight
    Vac Slots Close to the Front & Side for Better Edge & Corner Cleaning
    Solution Holes Are Only 1/16" Apart for Streak Free Cleaning
    Thin Side Profile for Better Reach
    10' Hide-a-Hose With In-Line Filter
    Super Comfortable Design for Less Hand Fatigue
    Easily Replaceable Cleaning Head - Only $19.95
Retail value is $395
Auction starting price-$200 w/ $5.oo minimum increment
Free shipping to the L48
Auction ends April 24th at 6PM pst
Use a bane tool for ten years. Man that thing is brutal.
My speed has picked up a lot on furniture with the sheardry. lm half tempted to get another but I'd like to try the SS.
The pee spot feature isn't as bad as you'd think but there is some dripping/splashing that happens a bit.
The force of the water isn't as strong as the SS either as there are more holes.
Ergo wise, I'd like a bit more knuckle room
And the opaic shell sucks.
But the center spray bar does provide extra aggitative which helps on some fabrics.
It's easily the second best low moisture tool available.
