Wandslinger
- Oct 7, 2006
- 1,006
- Name
- Tom Meyer
I cleaned a carpet last week which was a nice off-white nylon looped designer carpet. It had never been cleaned before. I pre-sprayed with soapfree and then extracted using LAST STEP by CTI. The customer called and said the carpet dried a bit stiff.
Now, when I was cleaning she opened all of the windows and there was a fairly good and dry breeze flowing through. Typically I would warn my custy that it might dry stiff because of the low moisture in the air and make the comparison that it's like what happens to a towel if you dry it outside versus tumble dry in your dryer. I tell them that it will eventually soften up. Unfortunately the custy left at this house and she wasn't forewarned so now it's like I did something incorrectly.
My question is, would you rinse with just water, encapp with a CRB to soften the fibers up, rinse with an acid or rinse with a rinse agent again?
