Suggestions?
Cleaning Professional
Since you chimed in and live in the desert, has this ever happened to you?
I have seen area rugs dry out side get stiff some times. Chalked it up to much chemical and fresh water rinsed
Same with a few wall to wall carpets.
Just went back and rinsed.
Makes sense though because you didnt use any thing that should do that.
Reactions: Wandslinger
Zee
What if it really has never been cleaned and somehow the residues from loom oil or factory protector got it stiff?
Does carpet fresh foam up real bad?
You know ... I have not had it foam and plug up my machine but really cannot recall foam... Just white powder residue and stiff after cleaning
If you took the stiff towel from drying outside and ran it in the dryer, after some tumbling it will be soft. It just breaks the left over minerals from the water.
That's what a good vacuuming and or a CRB may do without the rinse.
Did you try that?
Hell you should've just
Lied and said I applied free water guard mam
Reactions: Lint Basket
A stiff carpet retains it's upright position longer. It looks great.
Nate The Great
Just be straight with them and tell them you mixed up the prespray with a bottle of viagra...
