PMF UPHOLSTERY TOOL REPLACEMENT VALVE
Oh my word Mr. Fancy pants! Judging those of us that prefer to do the lower end apartments and section 8 housing!
MAY GAWD HELP ALL OF YOU POS!
You could buy the 120 psi 3 1/2 inch clear head tool and put that westpak valve on it.
U1560PS 3 1/2 inch
AC33 3inch SS clip on glides.
www.pmftools.com
Make sure and order the bracket
Lighter and able to see what you're extracting. And the length of the head is not as long. It's cheap enough to try out.
Back in the 90's I went through 5-6 of them. Not bad for the times, replaces heads when they cracked, plastic jet as it wore. I like the light weight and wished they made something better.
If only someone would make a high quality plastic upholstery tool. Huhhhh :winky:
Reactions: Mike Pailliotet
BradFenstermaker
Dude! Called Westpak mid day Friday to order my bracket.
Shazaam it arrived to today 1st class USPS.
That's awesome service.
Thanks to Craig that took my little order.
I used that westpak valve yesterday on a chair, and it felt 100 times better than the pmf valve. For anyone that still has the stock pmf valve on their upholstery tool...what are you waiting for? Go get that new soft touch upgrade
I bet the stock valve is for 55 psi pumps.
Interlink is too slow to order just go to westpak.
I thought they had the valve in stock.
BradFenstermaker
I like the feel of my new westpak soft touch.
Bracket and valve placement was tricky but got it squared away.
Cheap upgrade IMO
Yeah I ordered 3 for all of my tools. $21 for the valve and $4.50 for the brackets.
If you idiots had a Devastator wand you wouldn't have to worry about hunting parts.
