Westpak HS wand preview
I was able to tighten up the Swivel with channel locks and tighten up the play and action considerably
Reactions: Bob Pruitt
Bob Pruitt
Robert Pruitt
Not too sure about the way the brush split in the front. Need something before Scottsdale.
All of our brushes are split in the back.
Somebody slid on the brush the wrong way.
Enlarge the photo to see it clearly.
http://www.cobbcarpet.com/zen/index.php?main_page=product_info&cPath=76&products_id=5509
Reactions: Erik and hogjowl
joey895
Joey J.
I think going with a 2 inch tube and that wide of a vac opening you will lose suction. Water will gurgle out like using a portable sucking up a flight of stairs.
Interesting. Then blower size may matter.
CraigT
Craig Tyler
The split is supposed to be in the back, I'm going to have another talk with my guys again about it. Any other feedback will be appreciated.
Those hoses are standard wire braided vinyl coated hose.
We are also considering a 12" head version of this tool with 2-jets. We've got drawings made up but waiting on some more interest and feedback from some of our clients.
Well..
On Vinyl floors it's a near twin of the HF wand.
A bit more water escapes from the ends (110s should swapped out to 95s)
Brush ring flexes more due to no support ring
Ergos are more traditional but the handle needs to held higher than the HF for good extraction
The 14" on both tools is too wide and hard to fight to get much benefit out of the swivel. It should be rigid and have a 12" option with a swivel.
Both tools would benefit from a much narrower vac slot to speed up velocity.
A glided wand is quicker on LVP as it is....
todg
Michael Marcus
Well..
To make a long story short, don't waste your money on tools that sit in the garage or van? Can anyone come up with a wand "like" tool for tile and grout cleaning that is effective?
CraigT
Craig Tyler
Thanks for the input Mike.
Did you like the flex on the brush or would you prefer the support ring?
Those 110's are pretty close to the edge so I can see where the 95's would help.
We've got drawings done of a 12" with 2-jets, but haven't produced samples of it as of yet.
I think the support ring is a good idea. Fix it and I will buy. No swivel.
For a very good price : )
My dream HS wand would be a 12" swivel, 6 jet, narrow vac chamber, brush ring with sliding support.
There is no need for the giant vac chambers on these wands.
The 14" should be rigid imo. Too much effort to control and doesn't work along toilets anyways..
Craig, bring a note pad to Scottsdale.
When a carpet wand's narrow chamber sucks the water up with ease, that should be a hint also to make it more narrow
