What machines are you using to clean hardwood floors?
Montana
Swani
I'm looking at adding hardwood floor cleaning to my business. I will be using the hydro-force line from Interlink. I've looked at possibly purchasing a Lindhaus machine from Interlink or possibly a multiwash scrubber from powr-flite. Has anyone had any experience with any of these or a similar machine?
Heart of Dixie
Nick, For economy, the 175. But I use a DP-420 "Hydrocare" which is similar to the Multiwash line. Here's why: Wood floors need to be deeply scrubbed with the grain and along the edges of the boards where stuff has been accumulating. A Floor wand would work fine and if you already have one, use it.
But a machine that wets, scrubs and recovers all at the same time is invaluable and is a low impact and low moisture process.
I've no experience with the machine Interlink sells for hardwood care, but you can see why it would work. However, A Multiwash would give you the muscle to do VLM on carpet, or just pre scrub for extraction.
I guess a quick scan with Searchtempest would help you see what is out there. In my case the Hydrowasher happened to be nearby for only $600. Couldn't pass it up and have never regretted it.
Reactions: Living The Dream
We have used a hard floor wand followed with a flat mop to dry and spray on bona or Murphy's as we mop. Dries in about 15 minutes with fans.
Montana
Swani
Great info! Thank You!
Reactions: Old Coastie
Tom Forsythe
I am a little nervous about a cleaner new to wood using procedures with too much water. There are 3 machines that I am aware of that extract with controlled moisture with the current recommended Bridgepoint System: one is the dirt dragon, one is the Lyndhaus and the other is a Karcher (do not recall the model but the same concept as the others).
Heart of Dixie
Mrice
Fl
Mat
I've got a multwash and I like it for wood...but it cuts a narrow path so a 175 is faster...but I feel this cleans with the grain better.
Montana
Swani
Do you ever have over wetting issues? When you clean with a 175 how do you clean up your solution?
I do only 2types of hardwood servicing
A very light cleaning with a mist of hardwood floor cleaner over the floor, then lightly mopped up with just fresh water
Or, for heavier abused floors, I do the maroon pad with two coats of finish
