RICHARD. ..BEST ADVICE EVER
La La Land
Richard. .your advice on using the MMR was spot on...we sprayed it on the mold area. ..it was lik magic. ..first it bubbled up and then jus disappeared completely. ...mopped it right up...now doing second application. ...amazing!
Thank you...
Ann Arbor
Steve Lawrence
Thank you...
Pardon my ignorance but what is MMR? ( I only come up with mumps, measles, rubella--a vaccine.)
Reactions: hogjowl
Ivan Turner
Jefferson City Missouri
Ivan Turner
MMR Rocks! Always take the product serious. Yesterday we completed a MRD project and one of my guys failed to wear his googles, even though it is a standard policy and got some MMR in his eye. Very caustic stuff, but needs to be applied the right way.
La La Land
You can actually see the fumes in the air......
I gots the "Richard " discount from Jon Don......ask for Mark!
The only problem was the goggles. ..
They had a vent hole....luckily I had some swim goggles that sealed tight!
All done...got a fan drying it all out. ...my basement looks...
JUS LIK NEW!
But like I told you it isn't remediation but will remove staining from surfaces. We used it after remediation on jobs where they are still concerned about staining. Its mean stuff, not to be taken lightly.
Glad it did what you needed bawb! :biggrin:
La La Land
The guy that installed the new toilet didn"t insure the tank was tightened down.... (Joans nephew)...
So it wasn't sh*t water after all..
kinda odd you didn't notice water on the floor then.
two places a tank can leak..thru the bolt holes that secure it to bowl and thru the tank/bowl gasket.
when bolt hole leak, it drips all the time .
At gasket, when you flush .
Both conditions you see water on floor around the toilet
.L.T.A.
Prattville, Alabama
.L.T.A.
When you bend over does your butt crack show?
kmdineen
Redding, CT
Kevin Dineen
I took Ken Sellers AMRT course this spring. A couple of guys in the class liked RMR mold stain remover and said they pass post-remediation evaluation without sanding or brushing. I don't think they HEPA vacuumed either as the product penetrates into the affected material. It is nasty stuff like the MMR, full PPE required. Have you tried this product?
No I have not. I can see where it could pass but its still does not meet anyones requirements for mold remediation. I think it is a valuable tool but I would be cautious how its represented.
There are times when the property owner doesn't have the funds for a full blown mold job. Maybe using some containment and hepa vacuuming with a mold stain remover is the answer for these cases. ???
Here is a good article by Michael Pinto a leading authority on Mold, speaking about Mold Stain Removers.
https://www.fastmoldremoval.com/wp-...tain_Removers_in_the_Remediation_Industry.pdf
