Prochem Titanium 6 jet. Help with jetting ....
  • Thread starter Supreme Clean Floors LLC
  • Start date
S
So I am currently running a stock Prochem Ti wand which came with 6 flow. I wondering what are the opinions on increaseing the flow for better performance. I am running a Sapphire Scientific 2500HS with these specs:
35 HP Kohler V-twin air cooled gas engine.
Water Pump General HTS2016S with an electric clutch producing up to 2500 PSI and 5.6 GPM at 1450 RPM.
Vacuum Pump | Blower Gardner Denver TriFlow® Ti-406 tri-lobe blower. Vacuum at 13 inch Hg and flows up to 371 CFM.
I also have ordered a slotted glide but I have yet to receive it but it will be installed on the wand.
I just do not want to go to much flow and sacrifice to much heat or not have enough cam and not be able to get the carpets throughly dry. Opinions on flow rate and angles would be great. Thanks
Reactions: Total_Rookie
9 will be a very noticable improvement.
If you're in a dry climate you may want to try 12.
Need more vac lift for higher water flow.
13" hg is too low. Should be 15".
Already mentioned #9 jet total on Facebook.
S
I just noticed the that the ss 370 has 16” hg but it has the same blower as the 2500 which is only 13” hg Why would that be @Larry Cobb
Just checked at the website:
Still says 13" . . . Behind the times.
Mikey had to change vac level on his 370, since he knows better.
The industry was @ 15" years ago.
