pre scrub, even when they aint lookin....you'll sleep better
and you'll have better day's off.
I prespray, run the 360i over it with no vacuum hose just to prescrub and after a few minutes, give it da biz.
That brush head is amazing.
You should try using the vapor steamer on it... Heard it works wonders...:stir:
Tony Wheelwright was a big advocate of using a steamer on upholstery... He had very impressive pictures of what the steamer would do when you super heat your solutions after you spray it on the fabric..:rockon:
380F is too hot for nylon, it makes the yarns unravel. I did that.
However, it is marvelous on mattresses.
Since getting the Devastator I think I've used my 360 about four times...
More power available from a wand or the unit behind a wand can make a difference. And add that little CRB... Mmmm... Good stuff
There are of course times where the Rotovac and brush head... Just glad I carry it for that moment we need it
Reactions: Old Coastie
