- Oct 6, 2006
- 117,376
and you'll have better day's off.
You really shouldn't need to prescrub if you are using a good rotary extractor. Plus, you'll sleep better.
I prespray, run the 360i over it with no vacuum hose just to prescrub and after a few minutes, give it da biz.
That brush head is amazing.
Too bad for your customers! j/k sort of...Since getting the Devastator I think I've used my 360 about four times...
You should try using the vapor steamer on it... Heard it works wonders...
Tony Wheelwright was a big advocate of using a steamer on upholstery... He had very impressive pictures of what the steamer would do when you super heat your solutions after you spray it on the fabric..![]()
Have you got some real pictures of that unit???I bet my edger gets used more than yours..
Yeah, you win, because that doesn't look like a pain in the ass at all.
My shark is a very powerful vac for edging and upholstery..when the vac head goes out, ill use exclusively for edging and upholstery. And get the oreck.
Dude, I think you need some sleep.Don't speculate..
Dude, I think you need some sleep.![]()
Looks like a great unit for upholstery.
Marty???Not at all.
Once you get the world's greatest carpet cleaning wand, then you can speak with authority.
Right Marty?
