- Oct 6, 2006
- 116,959
Should be EZ.I want to get 17" of Texas sized lift..
Is this going to be the next "Best" thing? You move too fast. I still haven't got my red handle
And good morning.. My day should be interesting. My notes say my first job requested I wear booties. Here I go.
DO NOT GLUE THE CUFFS ONTO THE HOSE. If you do, that cuff is useless if you get a split etc
Never ever used a cuff myself on a hose. If they come with cuffs I just remove them.
And always used stainless 2 inch thinwall tubing for joiners.
Zero leaks.
So use electrical like Teflon tape?electrical tape works much much better.....you can pull it and make it stretch a little and it will form itself into the ribs of the hose.....
thats a first....
yep...that is all I have ever used since day one........tighter fit and last much longer.......
make sure you put it on the same direction that the cuff screws on so it tightens the tape...not backwards so it loosens it...
Does Rob have an instructional video?, I'm not grasping what you're saying..
What's next? Is someone going to start using a cheese grater to make a Fels prespray?
You failed to see my thick sarcasm.whatshisbutt has been doing that for years........
To late Damon, I already make ‘Fels Gel’ from left over Fels nubs.... use it to clean shyte area rugs in the shop..... works fookin great..... 360i BH to scrub/rinse....What's next? Is someone going to start using a cheese grater to make a Fels prespray?
Mike, just use Teflon pipe tape.....So use electrical like Teflon tape?
thats a first....
