C
carpetcleaner
Anyone know if these can be interchanged or what the differences are?
No. The airflow is horizontal.Is is this vertical?
Like bawb's?Use old feet.
Some unit did not have removable feet.
YepIn the blower pictured
The configuration is horizontal but...
The airflow is vertical
I think the feet bolt on and are made to fit the housing whether mounted the tall way or the flat way. Maybe this is a new thing... or maybe I'm out of date. Pay attention to which blower lobe shaft extends through the housing to mount the drive pulley if you want to fit the blower to your existing set-upYes, except the V in the code stands for vertical. Meaning the cast feet are on the end, usually not movable.
