darcie smith
If you have a company credit card that you let your techs use to purchase gas or necessary supplies for jobs, do you have a written company card policy that I could take a look at (or shamelessly modify for my own needs)?
Famous last words.Oh well then I'm not the idiotNot my circus, not my monkeys
The two techs we'd be giving them to are very responsible. Well, one of them is. The other one is a relative so she knows better.
haha, Marty go soft, of course he's soft, do you know how old he is.Are you going soft?
True!!If you can't trust your employees with a credit card then why would you trust them with your business name, reputation, and customers?
All the free air miles some of you are missing out on.
After looking at WEX, what card had the options you mentioned here?We use to use Fuelman Gas cards. Recently switched to WEX. Each tech gets a pin they have to input into the pump each time it’s used. You can set spending limits per 24 hours as well as say how many times they can gasup in a 24 houf period.you can also limit what each card can be used for (ie unleaded gas only, diesel only, or both, oil, wipers, drinks, etc...) there’s a ton of flexibility to fit your needs. We save .10 per gallon. Our techs gas up st the completion of their route EVERYDAY regardless of how much they used. At the pump, the driver has to input truck mileage (after his pin) before pumping, that way you can run reports per truck to see how much fuel was used and how many miles were driven and compare MPG. Hope this helps
I believe we went with the RaceTrac version of the Fleet card. When you set up your account you choose a “default” gas station. We chose RsceTrac. If your drivers fuel up there it’s your greatest savings (the savings increases with the total monthly gallons purchased as an account). Your drivers can stillAfter looking at WEX, what card had the options you mentioned here?
