Rhino or Linex
clean image
Carl Maddock
rhino a bit cheaper
Linex guy says rhino is absorant
Auto forums say linex bit more durable
Trying to get feed back who may haves either or both
I dunno
But if you can get one that’s smooth
Get it
Cuz roughy, black rhino catches everything
Matt Ross
Linex is a better product, but both are only as good as the installer. It's all in the prep work and install. I've seen problems with both and it's usually poor prep work.
I did it myself with this stuff:
http://www.jegs.com/i/Duplicolor/31...MIvv2QgObJ2QIVFrbACh0kJADiEAYYAiABEgLgZ_D_BwE
It was cold when I did it.. I think hotter weather would have been better. I'm thinking smooth would have been better but I saved about $600.
rhino a bit cheaper
I've had both of those and two other brands and to be honest can't tell a difference between them.
All of the professionally applied products are tough enough to stand up to use in a cleaning truck. Rhino is slick, and ice-slick when wet, and anything not tied down will slide around. Regular Line-X is like sandpaper comparatively, but that grip keeps it from being slippy. The Line-X guys have come up with Line-X Pro, a product that is about halfway between rough Line-X and RhinoLiner.
Good luck with that. We found the Dupli-products to be less durable than regular paint. We had good luck with Herculiner, until about the five-year mark when it starts to break down and peel.
Pick the one you like. If they happen to be higher, ask them if they will do it for the competitors price. Tell them I said they are all the same. :winky:
I agree that it dosent seem that durable, I'm hoping it needs to cure some more.
Looks like im going with Rhyno for this Transit build.
The Vegas Interlink is a Rhyno applicator.
Not sure what's on mine but I got a piece of carpet for $35 to lay on top of it.
I'll pull it out occasionally to clean it and replace it if it gets too fugly.
should help with noise too.
jwfoulk12
Justin Foulk
Linex is better from what I understand. I have Linex on mine covered by the factory rubber floor.
Latest Auctions
